ABS light on after hard braking - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-23-2013, 03:24 PM Thread Starter
Hi there,
I have an F350 2005 I recently replaced all the brakes around 2 months ago so I know they are all good and stop well. Today I was driving and a semi flew over lanes and nearly wiped me out, I slammed my brakes on as hard as I could and all was good I felt the ABS work etc I managed to stop in time. Then forward 30 miles of driving I was just driving home and the ABS light has come on. Each time I turn the truck off and then back on it reappears. I have checked the fluid and that's fine and the brakes are still working ok.
Any ideas what it could be?
Phil
Phi1 is offline
post #2 of 5 Old 05-24-2013, 04:52 PM
PHYRMN's Avatar
From what I understand the ABS system codes can tell you whats wrong but, the ABS codes cant be read with a regular scanner. Either a dealer or someone with Auto Enginuity software should be able to tell you what has caused the system to throw a code. Typically its a sensor thats not working properly.
2011 F350 King Ranch DRW No Mods Yet
SOLD 2003 Excursion Eddie Bauer 6.0l 4x4 | 2004 Intake | Zoodad Mod | Upgraded HPOP Cover | ARP Studs | OEM Headgaskets | Updated Turbo Feed-Drain Tubes | EGR Delete | Coolant Filter | Altas 40 | MKM Street Tune | Banks 4" CAT Back | Muffler Delete | High Idle Mod | Blue Spring Update | 6.4 Banjos | CCV Mod | Glowshift Gauges (Boost, Oil Press, Coolant Press, EGT, Volts, Fuel Press) | Rotella ELC | Rotella T6 | V/B Springs | Torque App on ASUS 10" Tablet |
PHYRMN is offline
post #3 of 5 Old 05-30-2013, 08:44 PM
There are abs sensors at each wheel, behind the rotors. I believe they somewaht magnetic, they get covered in crap over time and the signal stops flowing to the computer. U may want to pull the sensors and clean them. Its a common issue on many abs cars and trucks.
Gb
2006 F350 lariat 4x4, S&b intake, 4" exhaust, 03 turbo, sinister egr cooler, BPD remote oil cooler, BPD FICM, stc and dummys, diablowsport program, 5" lift, 35's, led fog bar, flatbed welding rig. SOLD. Went the darkside, 2014 ram 3500 daully.
gblauf is offline
post #4 of 5 Old 06-02-2013, 05:15 AM Thread Starter
I cleaned it and it's fine now no more problems!
Phi1 is offline
post #5 of 5 Old 06-02-2013, 07:19 AM
PHYRMN's Avatar
Good deal, thanks for the update.
PHYRMN is offline
