Steering likes to pull hard to the sides! - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-20-2013, 02:25 AM Thread Starter
This symptom happens so sporadic and widespread its hard to replicate it.. Happens probably once a week though.. I noticed my steering will some times pull hard to a side after I go around a very sharp bend. If I turn a hard sharp right afterwards when I try to straighten the wheel out it will keep wanting to pull to the right. I'm forced to hold the wheel hard and steady to the left to counter act to go straight. Same thing will happen for a sharp left turn.. The best way I've found to stop this once it starts is to hit a pot hole(or it'll go away after about 2-3 minutes of driving).. Whatever is locked up gets knocked backed into place or loosens up when I run something over.
I'm figuring its my U-joints or ball joints causing this.. but are there any other parts that could cause this problem?
Deiboe is offline
post #2 of 3 Old 05-20-2013, 02:34 AM
Term3's Avatar
My passenger u-joint was starting to seize up causing very similar issues.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #3 of 3 Old 05-21-2013, 10:31 AM
Always Faithfully Broken
6pointbroken's Avatar
try Curing Death Wobble - Tightening Up Your Steering - Diesel Power Magazine
2004 F350 SRW 6.0 ZF6 CCLB---SOLD
1997 F250 SRW 7.3 Auto ECLB
Rebuild in progress due to neglected Rust
2006 F350 SRW 6.0 Auto CCSB
Blue Spring, MBRP 4.0 straight pipe, Edge Evolution CTS 2, Dieselsite coolant filter, Dieselsite fuel/water separator, Bulletproof harness saver, Bulletproof HCFM drain plug.
2014 Focus ST
6pointbroken is offline
