Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum > 6.0 Drivetrain problems
Old 09-22-2006, 02:58 PM
RedX RedX is offline
Clunk question?
I was wondering if anyone could help. I have an 04 Excursion 4x4. I had a vibration in the rear end area and finally got that fixed. It had a roar and vibration at around 65mph. I found out that the Axle wedges were put in backwards. That took care of 90 percent of the problem. Then a new Drive shaft was installed. That took care of the problem 100 percent. This was the second dealer I took it to and they finally figured it out for me. The first dealer changed the rear end guts twice, thinking that was where the noise was coming from. That didn't work. Anyway I just wanted to give alittle history. Now everything is fixed and I hear a click in the rear end. It happens when I back out of my driveway and wihile backing I turn to either the left or the right. After I do this I then put it in drive and start pulling ahead and a little click/clunk type noise happens. If anyone has any ideas what the problem maybe I would appreciate your help. Thanks
Old 09-22-2006, 03:01 PM
jeshoyt jeshoyt is offline
Do you...
have a 2 piece drive shaft in your truck?
Old 09-22-2006, 03:02 PM
Logan Logan is offline
The Fat Mod
redx. Thanks for joinging powerstroke.org
Old 09-22-2006, 03:20 PM
1 piece. Thanks
Old 04-06-2007, 11:57 AM
midnite midnite is offline
Slip joints need greased.ford puts very little grease on them.go to ford-diesel.com for info.
Old 04-06-2007, 12:34 PM
ABOBB ABOBB is offline
Is it even worth it???
Welcome to Powerstroke.org RedX...
Hope you find your fix quickly.. I'm pretty sure you will, the techs that visit this site are pretty good.
Old 04-06-2007, 03:55 PM
nummit nummit is offline
How to grease the slip joint
Greasing the Slip Joint on the driveshaft. - Competition Diesel.Com - Bringing The BEST Together
Old 04-16-2007, 02:44 PM
powerstrokecwby powerstrokecwby is offline
the other thing it could be would be normal back lash in the gears i had the same problem and ford replaced the whole axle in the rear, to find out that when i went down thier i made them do the back lash check in front of me to show me it was good. hope this helps
Old 05-22-2007, 05:20 PM
lightninmike lightninmike is offline
Mine also makes the clunk noise/feel but i belive mine is in the front not the rear, although when taking off from a stop i can feel a little bit of slop being taken in. Ill have to check out that slip yolk, that didnt even occur to me
edit: **** wish i had looked at the date on this thing lmao
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
