Rear axle hub/shaft - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-13-2013, 08:27 PM Thread Starter
Herkybird88's Avatar
Rear axle hub/shaft
Any tips out there on removing a stubborn rear axle shaft on an '06 F-350 SRW? I removed all of the flange bolts, banged on it with a hammer, got it to come out about a 1/16 of an inch but no more. It's not like you can use a puller, since the center come out too.
Was just going to check brakes when I found axle oil everywhere. Not enough to leak outside the disc/drum assy, but parking brake components are covered.
Any help appreciated.
Herkybird88 is offline
post #2 of 3 Old 05-13-2013, 08:30 PM
700xxmaniac's Avatar
pry bar...
99 ford f-250 crew cab powerstroke
-skyjacker 6'' lift
- 395-70r-16 mickey tomson baja mtz
-sct tune
-stright pipe (vrrrooom)
-cops are in love with the thing
08 TRX700XX
-uni
-primary drive 13t
-pclll
-cp 11:1
01 recon es 250
-kenda 22'' bear claw
-53mph top speed
700xxmaniac is offline
post #3 of 3 Old 05-15-2013, 07:15 AM Thread Starter
Got it! Installed a gear puller, ran a long handle through the arms, and then pulled........HARD!!
