HELP!!! drive shaft lenght????!!!!!! - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-10-2013, 12:53 PM Thread Starter
big-red's Avatar
i have an 05 F250 4X4 it takes a solid driveshaft but i need to know the lenght....
i would measure the old one but it blew apart going down the highway and i can not find it. does anyone know the lenght i need?? please HELP
2005 6.0 f250, 6 inch lift w/35's, head studs, EGR delete, bully dog cold air intake, bull dog Triple Dog pup,4" TB exhaust
big-red is offline
post #2 of 6 Old 05-10-2013, 12:56 PM Thread Starter
big-red's Avatar
it is a extended cab short bed
big-red is offline
post #3 of 6 Old 05-17-2013, 04:26 PM
I have an 05 f 250 also ext cab short bed also when you say solid drive shaft? Mine has a slip yoke right after the trainy? Dealer should have measurements have replaced mine twice.
florida250 is offline
post #4 of 6 Old 05-17-2013, 10:37 PM
layson's Avatar
Quoted: 80 Post(s)
Measure the distance on your truck and give the driveline guy the masurements.
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #5 of 6 Old 05-18-2013, 02:29 PM
Sorry big red will measure drive shaft and try and.send pics had to spend some time with the wife been working.on truck.for.three.weeks now just did a egr cooler delet and oil cooler.
And brakes and caliper all.the way around
post #6 of 6 Old 05-18-2013, 02:40 PM
Have one Question though just looked at big reds mods on his truck it says he has 6inch lift wouldn't his drive shaft length have to be longer than mine. I do not have a lift on my truck.
Tags
driveshaft
