Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum > 6.0 Drivetrain problems
Old 02-24-2008, 10:20 AM
Rob Rob is offline
Free Faller
Send a message via AIM to Rob Send a message via MSN to Rob Send a message via Yahoo to Rob Send a message via Skype™ to Rob
driveshaft issues
so i have finally had the time to take out the shafts on the truck, cleaned them up and painted them up. none of the ujoints feel bad, there is no play/binding in any of them. also there isnt any play in the carrier bearing. i did notice that when they did my lift they had the carrier bearing bracket turned backwards. i dont know if it matters any but i turned it back the way it was supposed to be. i think ill replace my ujoints this next weekend as i havent had the time to go get the tool i need to remove the ujoints yet. i know i should have done it all while it was aprt the first time, but my kids have been keeping me busy at the sme time i have been trying to figure this out. anyone have any more ideas on why i am getting this vibration/drone??
Old 03-10-2008, 05:12 PM
deviusdragger deviusdragger is offline
well i get that slight vibration when taking off. but i also get that dreaded clunk when taking off hard on the rear end. So i guess im on the same boat as you walker. Sidenote thou, how do you replace the ujoints?
Old 03-10-2008, 05:19 PM
Rob Rob is offline
Free Faller
you have to remove the driveshaft, then remove the circlips where the joints are. then they need to be pressed out. they make a tool to do it. alot of peopel use a vise with a socket and hammer but i dont want to chance dinging it up. then put it all together, i know its a bit abbreviated, sorry. hope it helps.
Old 03-10-2008, 06:07 PM
Made perfect sense bro. thank you. Hope your problem gets fixed.
Old 03-10-2008, 07:22 PM
Rob Rob is offline
Free Faller
thanks and you too!
Old 09-14-2008, 01:40 PM
Rob Rob is offline
Free Faller
So, its been a while since i did any updates here, i took my driveshaft out, i was going to replace another Ujoint, but noticed that i was able to mount the shaft to a different set of holes on my T-case flange. I did that and took it for a drive, now my vibration is half what it used to be. a lot more tolerable, but still not gone. i think i am going to order me a new carrier bearing and have it removed and replaced, since it has to be pressed off adn back on. i am thinking that the driveshaft being mounted, with the u joints not all lined up may have bneen the culprit and done some damage to the bearing. ill update after i get the bearing done.
Old 09-29-2008, 08:10 AM
jwedel1777 jwedel1777 is offline
you might need a spacer for your carrier bearing, one that will lower your shaft an inch or two, so your drive shaft and u joints will be more in-line. Also, go easy on your sockets if you are using them to pound out your old u joint...I kinda smashed the suqare end on one together and had to take a die grinder to it so it would fit back on the ratchet.
Old 09-29-2008, 08:41 AM
Rob Rob is offline
Free Faller
it is already lowered, i talked to one of the techs at explorer pro comp, an they tell me that i am shimmed down too far. i am at 2 1/8 inches, he says that even their 8'' lift kits dont require more than an inch or so drop in the carrier. so i think i am down too far. i will buy their shim kit and install it, then update here what i find.
Old 09-29-2008, 08:44 AM
sikktruk01 sikktruk01 is offline
just take your complete d'shaft to the local driveline shop and have the bearings replaced and the complete shaft balanced. I've had several done for jeeps i've built in the past, it's not that expensive but use spicer parts (in my opinion) they are the the best.
Old 09-29-2008, 08:56 AM
Rob Rob is offline
Free Faller
i dont think its a balance issue, its more in the geometery of the driveshaft. i have to get it right before i can start spending money to balance it out. ( if that is the issue )
