Burning smell and hot rim Help! - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-27-2013, 11:47 AM Thread Starter
Angry Burning smell and hot rim Help!
Guys so today I swapped out my big 35's for a summer 33" hwy tire.. Prior to the swap there was no smell or heat on the rim.
Since the swap the front left rim is real hot and I can smell burning brakes or rubber basically a clutch burning smell for those who have smelt that before.
My question is.. No whining noise increasing with speed rules out the hub assembly.. Correct?
2nd question is the caliper? How can I isolate it to that sticking?
I don't have any metal wear bar noise that a low brake pad would give me, so in thinking caliper..
3rd replacement options.. Motor craft? Or what?
Thanks for help guys really need advice
2005 F250 CC SB 4x4
118k and counting
Mods list:
S&B CAI
blue spring mod
SCT livewire TS with Looney Tune
Bullet Proof Diesel 6 Phaser set to 58v
PHP FICM Tuner w/ Atlas 80
4inch DP to 5inch Straight (MBRP)
2.5inch lvling kit (ready lift)
Amsoil Bypass kit
DieselSite Cooland filter
18x9 gear alloy's w/ 35x13.50 Mickey T's Baja Claws
HID lights and fog lights conversion
ZooDad Mod
Re-badged "Peterbilt"
Granite State Diesels
brianjbeach85 is offline
post #2 of 5 Old 04-27-2013, 12:50 PM
To check the front hub/bearing, jack the wheel up and wiggle it top and bottom, there should be little to no play. I would think that if it is making a smell and not squealing, it is probably your caliper and not a seized bearing. You could try pulling the caliper off and seeing if it moves freely by compressing the pistons with a c-clamp and a piece of metal or the break pad.
Phil
phil_phil is offline
post #3 of 5 Old 05-15-2013, 05:25 PM
Sorry if you've already figured this out,but I just had the same problem and when I pulled the wheel the inner brake pad was worn almost completely out and the outer was still like new. Anyway the "float" pins on the caliper mount were seized from rust and disassembly and cleaning/greasing them freed them up and my heat/smell went away.
BobD981 is offline
post #4 of 5 Old 05-15-2013, 06:48 PM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
hope you got it fixed!!
Tom
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
post #5 of 5 Old 06-11-2013, 09:37 AM Thread Starter
Dropped it off at ford today.. Problem came back after I greased the pins. Thinking caliper but will post more when I get it back
2005 F250 CC SB 4x4
118k and counting
Mods list:
S&B CAI
blue spring mod
Amsoil Bypass kit
ZooDad Mod
