Clunking/popping from front left when hard over. - Ford Powerstroke Diesel Forum
post #1 of 2 Old 04-23-2013, 09:32 AM Thread Starter
MoserJR82's Avatar
2005 6.0 F350 4x4 CC KR SB with 149,000 miles.
I recently did a bunch of front end work, tie rod ends, drag link, upper and lower ball joints, axel seals.
Since then I've been hearing some clunking from my left front when I've got my steering maxed out either direction, though it's notciably worse when making a hard right rather than hard left.
Axel shaft went back in just fine on reassembly but it did leak a little oil (I'm assuming gear oil) while I had it apart which I haven't replaced yet because it was maybe 1/8 quart.
My hubs are manually locked right now because I have to retap the threads for the left vaccume line hookup. Would that make a difference?
Any help would be greatly appreciated. Thanks!
2005 F-350 KR, CC, SB 6.0L
Sinister EGR Delete
Final Charge Coolant
Rotella T6 5w40
Sinister Coolant Filter
MBRP 4" turbo back straight pipe
Blue Spring Upgrade
Droid Torque App
SCT X3 Spartan Hyrbid Race Tune
ARP Head Studs
Aftermarket degass cap
Cowl hood (not functional)
Atlas 80 PHP FICM tune
Rebuilt FICM thanks to FICMRepair.com!
Rancho RS9000X front shocks
MoserJR82 is offline
post #2 of 2 Old 04-23-2013, 07:15 PM
With the hubs unlocked can you rotate the front axle shafts by hand? If not, the hub on that side isn't unlocking.
My 05 has done it since new if the hubs were locked, in full lock turns. It will also click and pop more if the u joints are getting dry and are needing grease.
darenative is offline
