Slight slack in drivetrain - Ford Powerstroke Diesel Forum
post #1 of 8 Old 04-23-2013, 10:24 AM Thread Starter
MoserJR82's Avatar
2005 F350 KR CC SB 6.0. I've been noticing a little slop/slack/play when I press the go pedal from stops. It's not a ton of slack at this point, and there's no popping, clunking or vibrating at any speed but my truck has nearly 149,000 miles on it. Is it U joint time or is there another potential issue here?
It shifts great and my limited slip works as well as a Ford LS could/should with this many miles from what I've read. Not a huge issue at this point but I'd like to nip this in the bud before it becomes a more serious issue.
Thanks all.
2005 F-350 KR, CC, SB 6.0L
Sinister EGR Delete
Final Charge Coolant
Rotella T6 5w40
Sinister Coolant Filter
MBRP 4" turbo back straight pipe
Blue Spring Upgrade
Droid Torque App
SCT X3 Spartan Hyrbid Race Tune
ARP Head Studs
Aftermarket degass cap
Cowl hood (not functional)
Atlas 80 PHP FICM tune
Rebuilt FICM thanks to FICMRepair.com!
Rancho RS9000X front shocks
MoserJR82 is offline
post #2 of 8 Old 04-23-2013, 01:03 PM
thumper280zx's Avatar
Crawl under the truck and see if you can move the driveshaft back and forth by hand. If there is slack it could be your u joints if there's none maybe the tranny slipping a little may need to flush tranny and put new fluid in. I have an 06 f350 and my driveshaft is thought no play at all and I have 161,000 on it. So start with the easy an go from therr
Sent from AutoGuide.com App
06 F350 King Ranch
egr delete, coolant filter, sct tuner more to come soon
thumper280zx is offline
post #3 of 8 Old 04-25-2013, 03:55 AM
Pull the drive shaft and grease the slip joint, simple fix.
03 F-250 6.0 Black/Gold Lariat CC SB FX4
jsm180 is offline
post #4 of 8 Old 05-30-2013, 05:18 PM Thread Starter
MoserJR82's Avatar
meant to get back to this sooner. sorry for the delay. Could you be more specific? I pretty well know my way around the engine now after replacing a piston and doing virtual rebuild as a result but the drive train is another story.
I climbed under the truck and I can move the drive shaft quite a bit at the carrier bearing but don't know if that's normal or not. What do you mean exactly by the slip joint? I'll look into it more on the forums but thought I'd ask here first.
There's no "rotational play" in the DS at this point though. Thanks guys
Sinister EGR Delete
Rotella T6 5w40
Blue Spring Upgrade
Droid Torque App
ARP Head Studs
post #5 of 8 Old 05-30-2013, 09:59 PM
michaelbyoung's Avatar
There is a splined slip joint in the back part of the driveshaft. Disconnect the shaft from the rear end and pull the rear part of the driveshaft out. (I would mark where it goes) grease the splines. (Not to much as it makes it hard to reinstall) reconnect the driveline and that may fix your problem.
2006 F-350 Lariat Crew Cab Long Bed 6.0 Diesel
Chrome Pkg All Stock 185,000 miles
B&W Turnover Gooseneck w/ 5th wheel companion
ScanguageII High idle mod On board air
2011 Jumpseat Gutted Cat Mikeymod muffler
EGR delete CCV mod EC1 coolant Zoodad mod
2000 F-250 Lariat Crew Cab Short Bed 7.3 Diesel ***STOLEN*** 11/19/2011
4" Rancho Lift
215,000 miles
afe intake
4"turbo-back
IAH delete
Foil Delete
michaelbyoung is offline
post #6 of 8 Old 05-31-2013, 05:22 AM Thread Starter
MoserJR82's Avatar
Well I got it greased up last night. (note to self: set E-Brake or put in 4wd before disconnecting driveshaft from rear end)
It helped a little but not much. I think the culprit is the carrier bearing. I went to clean off some dirt with my finger and the rubber that the dirt was on came off with it.
Sinister EGR Delete
Rotella T6 5w40
Blue Spring Upgrade
Droid Torque App
ARP Head Studs
post #7 of 8 Old 05-31-2013, 05:16 PM
My carrier bearing was bad on my last truck, and I changed it first, it helped a little but the slip joint was the worst. Hope changing your bearing gets it right. When I was having my issues I thought for sure it was my rear end, but those two things did the trick. Good as new after that.
4" Rancho Lift
215,000 miles
afe intake
4"turbo-back
IAH delete
Foil Delete
post #8 of 8 Old 06-03-2013, 05:33 PM Thread Starter
MoserJR82's Avatar
mine ended up being the exact opposite. I greased the slip first and still had plenty of noticeable slack. Changed the carrier bearing last night and it's back to good. Actually acts like my truck wants to raise her front end now that the driveshaft isn't trying to arch!
Thanks for all the help guys!
Sinister EGR Delete
Rotella T6 5w40
Blue Spring Upgrade
Droid Torque App
ARP Head Studs
