4x4 question - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-19-2013, 06:13 AM Thread Starter
4x4 question
My shift on the fly deal isn't working with the hubs in the auto position, light comes on and my heat will still blow wherever I want it to.
I can put the hubs in lock position and then it will switch in and out of 4wd with the switch...so is it ok to have the hubs locked and drive in 2wd short distances?
Also any clue to my issue to fix this?
2003 F350 CCSB SRW
114k miles, ARP head studs, OEM gaskets, Blue Spring Update, EGR delete...valve still plugged in, 4" off turbo straight back, CAT coolant, Sinsiter Coolant Filter, Coolant Bypass/Recirculation, Gearhead Tunes SRL+ Daily Driver, Dashboss Monitoring w/egt and fuel pressure,Resurfaced head with new valves and guides,Banks Cold Air Intake, 04 Turbo Freshly Cleaned
rick5150 is offline
post #2 of 6 Old 04-19-2013, 07:24 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Thats fine, u can drive as far as you want, the only reason to not have your hubs locked is fuel economy and wear of you front axle parts. When you lock the hubs but not the transfer case it just means the front axle is spinning as you drive and turning the front drive shaft, but since the transfer case isnt engaged its just meaninglessly spinning. Its just like guys like me who only have manual hubs. we leave it unlocked unless we know theres gonna be some hairy situations we will get out and lock them but leave the t-case in 2wd until we need the 4x4.
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #3 of 6 Old 04-19-2013, 07:41 AM
chachi65's Avatar
Agreed. But to fix the issue might have something going on with the vacuum supply to front hubs might check that or could be the solinod
chachi65 is offline
post #4 of 6 Old 04-19-2013, 09:07 AM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
If your heat is still working properly and not reverting to "defrost" then your vacuum pump is working fine, so the problem is most likely at your hubs.
It could be the hub seals, I had one go bad with only 30k mi. on the truck.
or it could be a leak in one of the vacuum hoses going from either hub up to the vacuum solenoid on the passenger side fender.
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Bulletproof EGR cooler, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #5 of 6 Old 04-19-2013, 09:19 AM Thread Starter
Thanks guys, good to know...
I guess once its not slopppy slushy snow junk here in MN I'll start with checking the vacuum hoses for leakes or holes.
Im guessing the solenoid is for the vacuum pump and if either of those are bad your heat blows out the defrost which my heat Does Not revert to.
So im pretty much narrowed down to a leak in the line from pump to hub or something wrong with hub(s)?
2003 F350 CCSB SRW
rick5150 is offline
post #6 of 6 Old 04-25-2013, 05:59 AM
dxusmc's Avatar
Pretty much. Rubber lines might've gone bad or may have got themselves disconnected from snow and such. Otherwise there's a plastic disc inside the hub that looks like a cross that the vacuum solenoid pulsates to engage you ESOF. I've had them crack and get worn to the point the last time they broke, I switched over to Warn Manual Lockers and disconnected my vacuum lines and plugged them so they didn't interfere anymore
2004 F250 XLT 6" lift, 37" tires, zoodad, T6,
edge cs, k&n, revx, warn lockers, rhino bars
future: coolant filter, headstuds, bluespring, 4" turboback, tires..dam these tires
Marines 2004-2009
Army 2009-2013
dxusmc is offline
