Tightening Steering - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-14-2013, 01:12 PM Thread Starter
colonel angus's Avatar
Quoted: 2 Post(s)
Tightening Steering
My truck's steering has never been rock solid and after adding larger tires it's evn worse.
Any pot hole or rough road tends to move the steering wheel in your hands.
Can anything be done and is this inherent to our trucks?
Denny
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #2 of 4 Old 04-14-2013, 01:42 PM
mitchntex's Avatar
I had the same thing. changed out factory steering damper.Had 65,000 on it and was toast. then added dual steering stabilizers, worked perfectly, huge difference! 112,000 now, no problems since
mitchntex is offline
post #3 of 4 Old 04-24-2013, 06:16 PM
ZIKA's Avatar
The dampner will help but make sure that all of you rfront end components are not worn. Look at the upper and lower ball joints along with the pass side lower tie rod end.
06 F250 Reg Cab. ARP's, RCD Billet Powermax, Warren 190/100's, Areo A1000 Pump, Driven Diesel Reg Return, All AN Lines from the sump, Intake and Exhaust, 4" BDS Lift, Long Arm 4-Link, Dana 80 swap, 1480 u-joints, 4"/.108 driveline, Detroit Lockers (both axles), Warren Trans w/ Billet Shafts, Drive Flanges, 35"s, Traction Bars, Front Suspension Stops(For Tug-A-Truck), Rear Suspension Stops, Custom Hitch, Roll Pan, Lots of Drive Shafts, Axles, and Pinions.
ZIKA is offline
post #4 of 4 Old 04-25-2013, 05:10 AM
dxusmc's Avatar
new/upgraded steering stabilizer will help a lot. But like Zika said, check ball joints and steering components such as the Tierod sleeve, I've had the threads strip out on me before
2004 F250 XLT 6" lift, 37" tires, zoodad, T6,
edge cs, k&n, revx, warn lockers, rhino bars
future: coolant filter, headstuds, bluespring, 4" turboback, tires..dam these tires
Marines 2004-2009
Army 2009-2013
dxusmc is offline
