4 Wheel Drive Easy Question - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-25-2013, 10:00 AM Thread Starter
2003 6.0 F350 Crew Cab Dually
Where is the 4 Wheel Drive Control Module located and what does it look like? 4x4 indicator on dash comes on and goes off as it should when truck is first stated. Continuity tested all fuses...all good. No power on any wires to the 2H/4H/4L switch on dash. Obviously 4-Wheel will not engage.
Any help to diagnose would certainly be appreciated.
Striper Mike is offline
post #2 of 6 Old 03-25-2013, 05:40 PM
twoicebergs's Avatar
Quoted: 46 Post(s)
Check your fuses first. You need power to the switch before you go looking for relays. Search for ESOF.PDF.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #3 of 6 Old 03-26-2013, 08:41 AM Thread Starter
Been there, did that. Continuity checked all fuses, not just visually inspected. All fuses are good.
post #4 of 6 Old 03-26-2013, 09:06 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
The 4x4 module is to the right of the glove box, just pop it out and you can see it and it should have a big label on it saying something like 4x4 control module.
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #5 of 6 Old 03-26-2013, 09:21 AM Thread Starter
From what I had read only that is where people said it was located for the 2002, but was not sure if they changed it in the 03 version.
Thanks for the feedback, very much appreciated.
post #6 of 6 Old 03-26-2013, 09:23 AM
Chapter Director
Quoted: 5 Post(s)
Yea thats possible thats what i saw that one in, its possible they moved it for the 7.3-6.0 transition. If anything you could just pop the glove box out and look its right there in the 2002.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
