4x4 will not engage
Hey guys, my 4x4 wont engage unless I lock the hubs, then it works fine. Why is this?
Possible moisture in your vacuum lines, or if it's cold enough, iced up. I had this issue once.
I believe he is in Missouri. Do a check of your vacuum hoses and follow it up to the collector. It usually would crack near the axle hubs. If you don't find it visually, do a vacuum check of your hubs and of the system.
http://www.powerstroke.org/forum/att...works-esof.pdf |
