- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
ABS light and...
leaking rear differential
The tow/haul switch was flashing, ABS light was on, speedo wasn't working, and the truck would not accelerate. I replaced a VSS on the top of the transmission ( at the rear of the trans). The tow/haul switch stopped flashing, and the truck accelerated. But, it only accelerates for about a minute, then bogs. If I pull off to the side of the road, turn the truck off, and re-start it, it will accelerate hard again, then bog. The problems that still exist are: No speedo ABS light on Rear differential leaking from bottom of pumpkin and trans is now leaking Is it possibly the sensor on top of the pumpkin? |
| Sponsored Links |
yes ford has always had problems with speed sensor in rearend you could ohm it out but chances are it's bad |
My ABS light came on a few times while on the highway. The last time I noticed th Speedo needle droped off and back up and then the light came on. On a 6 speed where should I look for the problem.
| Sponsored Links |
