Need front end help - Ford Powerstroke Diesel Forum
post #1 of 5 Old 02-10-2013, 10:17 AM Thread Starter
drstephennix's Avatar
Quoted: 2 Post(s)
Send a message via Yahoo to drstephennix
Need front end help
I've got loose dust seals I guess. The rubber gaskets are loose on both sides; drivers and passengers. Anybody know what this means?
2013 F350 Platinum LB 4x4
35" MT's
74k miles
In the words of David Crockett, "You may all go to hell. I will go to Texas!" spoken in the halls of congress; circa 1830's
drstephennix is offline
post #2 of 5 Old 02-10-2013, 04:00 PM Thread Starter
Quoted: 2 Post(s)
35" MT's
74k miles
post #3 of 5 Old 02-10-2013, 04:13 PM
jse51599's Avatar
Those dust seals are just that.... they keep the crap out of your axle tubes. the seals that are leaking are on either side of the differential. You'll need to pull the diff cover and then the carrier to get to the seals.... you'll also have to pull the axles on both sides. Lots of work involved, that's why I haven't done mine yet....
6637, Diamond Eye Turbo Back, Riffraff Billet Intake Plenums and Intercooler Boots, WW2, Deleted EBPV
305 70 16 Toyo A/T IIs
Jim
jse51599 is offline
post #4 of 5 Old 02-10-2013, 05:27 PM Thread Starter
Quoted: 2 Post(s)
I don't think they are leaking actually tho. It's wet because it was raining here today and I had just got home. Any way to reseat the seals?
35" MT's
74k miles
post #5 of 5 Old 02-10-2013, 05:49 PM
jse51599's Avatar
I'm not sure if you can or not, but I would think if it's possible, you may still have to remove the steering knuckles.....
Jim
jse51599 is offline
