Limited Slip Isn't Working - Ford Powerstroke Diesel Forum
Old 01-27-2013, 02:27 AM
So I'm not real tech savy on the whole differential thing. I have a 2007 F-250 2WD and have noticed that when I do a burn out only one tire spins whether its in the mud sand or dry pavement. I have gotten stuck in sand a couple of times and and only one wheel was spinning. I thought a LSD was suppose to prevent that from happening. Is my Limited Slip working properly? Sure hope someone can help me here.
Old 01-27-2013, 02:46 AM
It's possible too much friction modifier was put into the oil.
Old 01-27-2013, 11:15 PM
The LS in these trucks sucks. Basically it's a clutch that applies some friction to get power to both wheels. If one wheel has good traction and the other has none, it won't help. If both have poor traction, then you should see both wheels spinning. If you want to have both wheels spin all the time then you need to look into a locker.
Old 01-28-2013, 06:06 AM
You need some division of traction such as 90:10ish or it only sends power to the spinning wheel. So, in your example, if your burn-out was pulling, it should engage. If it is really just spinning in place (like stuck in snow), you probably will get nothing on the other wheel. Exactly the opposite of what you want or need! Jack stand it and turn the wheel by hand. If they both go in the same direction you have limited slip and it possibly still works, well maybe! Change the fluid, and while the cover is off have a look for worn or broken parts. Make sure you have the correct amount and type of friction modifier. Burn-outs on pavement are very hard on limited slip units. Since it is 2wd, a locker won't really help you unless you drag-race or tow in slightly muddy or slippery conditions during the initial pull.
Old 01-28-2013, 06:11 AM
We wear the limited slips out on these truck pretty fast at work. They work great at first but most times after 6 months they fail. Now if their is a 25 and under give it 3 months...
Old 01-28-2013, 10:27 AM
Are you sure it's a Traction Lock rear diff? Not all Super Duty trucks came with that carrier. My XLT 4x4 was a one leg from the factory.
Old 01-28-2013, 04:23 PM
My old one was as well. Who would have thought a 4x4 would come without it.
Old 01-28-2013, 05:36 PM
The Ford LS is barely better than an open differential. Doesn't take much for them to stop working entirely. I put mine in the garbage when I swapped gears and went with a TruTrac.
