Rearend is spitting fluid by driveshaft connection - Ford Powerstroke Diesel Forum
Old 01-24-2013, 08:08 AM
There is fluid all underneath the truck where the driveshaft meets the rearend. Is this an easy fix?
Old 01-24-2013, 06:11 PM
I guess it is considered a pinion seal leak. FYI, i dropped it off at the local dealer since it is under warranty. I decided I'm not going to deal with it. I'll let you guys know the outcome.
Old 01-24-2013, 06:17 PM
Yup simple fix. Need a puller to get the yoke off, slide hammer with a screw in it works slick to pop the old seal out then tap in the new seal. I like the warranty fix though. Call me when it's done
Old 02-03-2013, 05:05 PM
Yep, agree.
Old 02-06-2013, 07:50 AM
Yeah they fixed it in less than a day and it only cost me $50 out of pocket. I like working on my truck, but HATE fixing leaks
Old 02-07-2013, 03:44 AM
I hear ya. I'm all for working on my own stuff but if there is a way to make someone else do it for free...yeah I'm all over it lol.
Thanks for the update.
Old 03-10-2013, 06:30 AM
Hey guys i also have a pinion leak at the rear, its not pouring yet but its wet and i noticed about a 1/16 of an inch up and down play on the pinion. Should i be concerned?
Old 03-10-2013, 06:37 AM
Yes
Do you know how to fix it? Seal and bearing.
Old 03-10-2013, 06:39 AM
make sure your vent tube is clear for one
it probably won't get any better with time if it is a pinion seal .
the fix if done correctly isn't as easy as mentioned in reality there is a crush sleeve that sets the preload on the pinion and the torque to set it is high
however people do mark the pinion and nut and count threads to loosen ,replace seal and re install nut to the exact same location
Old 03-10-2013, 07:08 AM
Ford Sterling 10.25 and 10.50 Pinion Seal Replacement and Future Upgrades | Diesel Trucks Blog & Discussion at Diesel Power Magazine
