[QUOTE=Valvejob;3408148]What my worry is, is that there is movement between the two blocks. If I install one solid block I'm hoping to eliminate movement between the two and the wrap would be gone(I hope).
It doesn't matter if its a stack block or one solid block you are gonna get wrap. It is cause from that space to begin with. I would still go with a solid block and good traction bar setup. OR a smaller block and new spring or just springs that is the best if you really want to get ride of axle wrap... |
Your best bet for eliminating wheel hop is to add traction bars!!!
Changing your stacked blocks to a single block will not do anything to reduce wheel hop! But having a single block is stronger and safer. Even going to new leaf springs with no blocks won't eliminate wheel hop, this is my setup and I still get some wheel hop. Here is a pic of my setup: |
Are we talking about fixing axle wrap or wheel hop?
Well axle wrap is the main cause of wheel hop, so both
