brakes sticking even after replacing all calipers! - Ford Powerstroke Diesel Forum
Old 12-03-2012, 04:36 PM
I had all calipers replaced after they went bad one by one over the past 5 months. Now today, i noticed the right rear is sticking a hair every once in a while. Anyone have this issue. We bled the **** out of these brakes too!
Old 12-03-2012, 04:45 PM
Powerstroke Techie
Feedback Score: 3 reviews
are you located in the rust belt?
Old 12-03-2012, 05:12 PM
no, i'm in florida. brand new hardware and we lubed the caliper pins with anti-seize
Old 12-03-2012, 05:13 PM
Illiana Chapter Director
Brake hose
Old 12-03-2012, 05:17 PM
what about the brake hose?
Old 12-03-2012, 05:19 PM
Sorry. Did you replace them when you did calipers?
Old 12-03-2012, 05:21 PM
no, didn't know i should have
Old 12-03-2012, 05:28 PM
You might have one that has collapsed internally not allowing the fluid to return like it should.
Old 12-03-2012, 05:49 PM
Feedback Score: 8 reviews
+1 for hose(s). I've had this problem in other vehicles over the years; Some hoses collapse internally and create a blockage which will usually let fluid TO the caliper (because of hydraulic pressure), but not back past the blockage... All of this adds up to a locked/stuck caliper. Bleeding it doesn't always identify any problems since the fluid usually has no trouble when it's forced under pedal/booster pressure.
Old 12-03-2012, 06:38 PM
Copy I might as well replace them all! Thanks for the info guys
