Front end pop clunk - Ford Powerstroke Diesel Forum
post #1 of 3 Old 11-19-2012, 05:17 AM Thread Starter
Front end pop clunk
When turning hard right or left at idle I get a pop/clunk in the front end 4X4 not engaged and is free. Only does this when turning hard like turning around.
Any thoughts?
2006 cc 4x4,Rotella 5-40,Amsoil bypass filter Dieselsite coolant filter, edge evolution, K&N air filter, high idle mod, zoodad mod, 60 gallon Titan Tank, blue spring kit, Airlift 5000 bags, Bilstein hd shocks, MBRP 4 inch st pipe turbo back, welded egr cooler
rowcoach is offline
post #2 of 3 Old 11-19-2012, 06:37 AM
twoicebergs's Avatar
Quoted: 46 Post(s)
You have to lift the wheels off the ground to check for play. It could be as simple as drop-link sway bar bushings to ball-joints or bearings. A good pry bar will come in handy.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #3 of 3 Old 11-19-2012, 06:37 AM
Bluedemon6.0's Avatar
Send a message via Skype™ to Bluedemon6.0
Check your bushings on your shocks, it sounds like it could be a worn out bushing in your suspension somewhere.
Sent from my PG06100 using AutoGuide.Com Free App
-Steven
New!! 2015 Mustang ecoboost!!
Sold!!
formally owned:04 6L PSD CCSB
Studs
Egr delete
S&b intake
New dashboss with fuel pressure and egt
Sct Looney by Vivian and Tonywildman xtreme early lock up now
php 140x
63.5/88mm 06 turbo with a pmax billet WW2
PHP Atlas 80
My baby-
87 jeep wrangler
350 and 700r4 built by mad dawg transmission
Dyno @ 200hp and 400ftlb at 3100 rpm
On 33s
Bluedemon6.0 is offline
