2004 f350 front end issues. - Ford Powerstroke Diesel Forum
Old 11-18-2012, 07:01 AM
My truck has had this issue for some time and I can't figure it out. To start at almost any speed I can feel and hear a light grinding it will vary when I touch the go pedal. Truck also is pulling pretty hard to the drivers side exspecially at highway speeds. And when a apply my brakes at about 45 to 40 mph when slowing down I am getting a bouncing/shimmy until about 30 mph. I took the wheel bearing hub assembly apart and noticed the bearing and knuckle seal have been making contact and rubbing on each other. Any ideas would be great. Thanks guys
Old 11-18-2012, 09:43 AM
When you took it apart how did the axle shaft look where it goes through the wheel bearing/hub? those needle bearings can go bad and chew up the axle
Old 11-18-2012, 01:05 PM
I noticed no wear on the shaft I thought the same thing myself.
Old 11-27-2012, 02:52 AM
It sounds like a wheel bearing the way it hums a bit. But it's the third one I've put in. I also have warn pro hubs installed.
Old 12-02-2012, 11:55 AM
Also I have a difficult time removing and installing the axle into the differential. It just doesn't slide in or pull out. I either need a small bar or dead blow to install.
Old 12-08-2012, 05:53 AM
Any ideas anyone?
Old 01-20-2013, 05:31 AM
Up to the top
Old 01-28-2013, 06:51 PM
Re: 2004 f350 front end issues.
Bouncing/shimmy on the brakes is usually a warped rotor.
With axle on jackstand, grab tire at 6 & 12 and shake, then try again at 3 & 9. Could have a bad bearing. Prying up with a pry bar or length of 2x4 will tell if ball joints are bad.
Sent from my LG-VS700 using AutoGuide.Com Free App
Old 05-15-2013, 12:50 PM
I have now replaced both wheel bearing caliper and rotor on drivers side and rebuilt the front driveshaft. Trucks still pulls to the left and bounces. I can watch the wheel twitch to the left more and more when braking. when towing its a little worst with the pulling.
Old 05-16-2013, 07:00 AM
Does your steering wheel shake violently? If so I would check ball joints, and the track arm.
