'05 f250 front axel seal replacement?
so i was changing my rotors and pads yesterday and noticed my dust seal was lose (which i was told is normal) but the seal behind that, that hold the oil i assume, is leaking "oil" on the . how hard is this to fix and whats the seal run $ wise? its the front left axel seal.
You must completely strip the front end pull the axles, diff gear assembly, then pop the seals out from inside the diff housing. I used a special press to install my new seals.
damn........ i think this job may be outta my ability
You can do it. It's not hard just takes time.
If the seals have already fallen-out of the axle housing you might as well take a pair of side cutters and remove them so they are not flopping around as you drive. That's what I did about 6 months ago on my 06. Someday when the front end needs work I will install the newer updated seals that don't fall out on their own
The outer seals are more like dust covers. Nothing to worry about. As mentioned above, the real seal is at the differential.
the dust seal is off, but there is oil coming out.. so that means its the seal at the differential correct?
yes your inner oil seal is leaking
the new dust seal relocates from the axle shaft to the axle tube ,, and can actually mask an inner oil seal leak ,, |
correct the inner seals are bad
