Replaced everything, Still Squeaks! HELP! - Ford Powerstroke Diesel Forum
Old 09-13-2012, 06:19 PM
Question Replaced everything, Still Squeaks! HELP!
So I have a squeak that sounds like it is coming from the drivers front wheel. Only hear it above 25 mph.
I needed to do brakes so I started by replacing the rotors, pads, and calipers. I made sure the heat/dust shields are out of the way.
I replaced the wheel bearing assembly $300. Still squeaks.
I have Warn hubs (so the axle shafts should not be spinning). I removed the hub and drove without it, still squeaks.
What else is left?
Old 09-14-2012, 04:18 AM
Makes the noise driving straight, doesnt change when turning either direction.
Tags
caliper, hub, rotors, squeak, wheel bearing
