Rear brake pistons seem stuck on one side - Ford Powerstroke Diesel Forum
post #1 of 12 Old 06-27-2012, 04:33 PM Thread Starter
LTRMC02's Avatar
I drove my truck a week ago and noticed once parked that the driver's side rear was hot, I heard a ticking noise so walked around the truck and could tell this wheel was too hot so I finally got time to look at it this week and I see that the other side had a leaking hub seal so I've pulled the hubs had the rotors turned and all.
I used a C-clamp and pressed the pistons in on the passenger side caliper without much pressure at all then went to the drivers side and could not get either piston to move much, if any. I applied even pressure to each piston so not to **** it but it's like there's hydraulic pressure keeping it from pressing in. It appears both rear calipers are plumbed together so if a valve upstream wasn't letting fluid return to the reservoir then the other side shouldn't have pressed in so easily should it I didn't think to try opening the bleed valve to see if I could press them in with it open. Note this is the side that seemed to have stuck the other day. Both sides had the pads worn down just before getting to the metal so the pistons were fully extended.
Any ideas or something I'm over looking?
LTRMC02 is offline
post #2 of 12 Old 06-27-2012, 04:50 PM
6.4ford's Avatar
All I got to say is replace the whole caliper along with pads and rotor of it worn out. I had the same problem on my drivers side back wheel. U see there's 2 pins that the caliper slides on. If those pins seize then the caliper is going to stick. Below is what will eventually happen. This happened when my caliper was stuck for a long time. If u want to back the pistons off. Open the bleeder valve it's easier although I backed mine off without having to do so. If ur pistons don't want to go back u might need a new caliper. If u have anymore ?s I'm here to help
6.4ford is offline
post #3 of 12 Old 06-27-2012, 04:56 PM Thread Starter
LTRMC02's Avatar
That was my first thought of the slide pins maybe sticking but after I pulled it apart I see the slide pins are very smooth. Just curious of what all could be keeping the pistons from being pressed back in, they don't look mis aligned or anything. It'll be friday before I get back over to work on it but I'll try opeing the bleed valve to see if it's hydraulic pressure holding them out or if they are hanging in the piston cups for some reason.
LTRMC02 is offline
post #4 of 12 Old 06-28-2012, 07:29 PM Thread Starter
LTRMC02's Avatar
LTRMC02 is offline
post #5 of 12 Old 08-16-2012, 08:27 AM
hornythrony's Avatar
I and my father in law both have 05's i bought mine with both rear calipers seized and i have done both my father in laws too its a common thing on these trucks i hear. The in laws went one by one more then 6 months inbetween but when they did sieze you knew it that rim and hub were hot (long trips to work) and it was even smoking due too the hub seal melted and leaked, so i would look at them to and do them at the same time if your inthere cuz it s not hard to do seals if you got the right tools
hornythrony is offline
post #6 of 12 Old 08-16-2012, 08:32 AM
ZMANN's Avatar
Quoted: 1779 Post(s)
my neighbor wore his rotor down to the cooling fins when his caliper seized
I got him the part #'s from autozone for a loaded caliper .. it has all new hardware /pins/crush washers etc around $60 rotor was about the same $
We Miss you Ronnie
ZMANN is offline
post #7 of 12 Old 08-16-2012, 08:36 AM
Bouchardtowing's Avatar
Replace the caliper with pads and a rotor. Calipers freezeing happens more then people think. We replac3 probably 12 to 13 calipers a week. Its old and tired lol:thumbup:
Bouchardtowing is offline
post #8 of 12 Old 08-16-2012, 08:41 AM
ZMANN's Avatar
the 6.4 caliper in the pic has dual pistons ?
My 06 doesn't IIRC I wonder if you could swap ,, or if it would be worth it ?
or if I am tarded and just can't remember if we have duals lol
We Miss you Ronnie
ZMANN is offline
post #9 of 12 Old 08-16-2012, 09:03 AM
jimmyv13's Avatar
Quoted: 47 Post(s)
Feedback Score: 3 reviews
Send a message via AIM to jimmyv13 Send a message via Yahoo to jimmyv13
I just did my rear brakes....open the bleeder, use a c clamp or a large pair of channel locks and put the old brake pad against the 2 pistons so they move together. They should move back with some pressure.
2015 F250 CCLB Lariat Ultimate
jimmyv13 is offline
post #10 of 12 Old 08-16-2012, 02:17 PM Thread Starter
LTRMC02's Avatar
My passenger side pistons pushed back in easily this way but the drivers side was stuck. I sprung open a C-clamp putting so much force on it trying to push them back in. I even tried to push them in again when the caliper was removed from the truck and brake line but these pistons were stuck. I change this caliper out with one from AutoZone as well.
LTRMC02 is offline
