Sway bar - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-15-2012, 01:21 PM Thread Starter
Quoted: 2 Post(s)
Sway bar
Should the front sway bar have any movement side to side? I'm trying to figure out what a popping noise it from the front of my truck from time to time and I was checking the sway bar and I am able to move it from side to side about 1/2 an inch.
Thanks,
Rick
2016 F350 Platinum
ralderman is offline
post #2 of 4 Old 07-04-2012, 03:58 PM
Mine is doing the same thing. The trac bar was loose at the cross member mount on my 2003 F350 dually and that helped some but there is still a poping noise and i believe it to be the sway bar moving. Sorry I don't know but maybe someone that does will reply.
seeemmiss is offline
post #3 of 4 Old 07-04-2012, 05:22 PM
asian195's Avatar
Quoted: 2 Post(s)
Check your shocks. My shock bushings and my track bar bushings were worn and popping.
Sent from my PC36100 using AutoGuide.Com Free App
2003 F-350 6.0L.
Leveling kit
35/12.50-20 Federal Couragia M/T
20x10 black Fuel Hostage wheels
4"-5" exhaust no cat
Airaid intake
SCT tuner-awaiting custom tune
Edge Insight CTS
Blue spring
6.4 Banjo bolts
Zoodad mod
EGR Delete
To Do/Wish list:
FICM tune
ARP Head Studs
BPD Oil Cooler/Filter
Fog light mod
Harpoon mod
Injectors 155cc
asian195 is offline
post #4 of 4 Old 07-04-2012, 07:47 PM
Quoted: 50 Post(s)
Thanks,
Rick
It's okay for the sway bar to slide a little side to side, especially the 05 - 07s which have the "bayonet style" lower end links. As long as there is no metal-to-metal contact when doing so, it should be fine.
Check the track bar ends (upper and lower), the steering stabilizer, lower shock mounts, ball joints, and front axle U-joints. Jack the truck up and put the front end on jack stands so you can check each component individually with the suspension unloaded.
WARNING: Be sure to use appropriately-rated jack stands, and to set the parking brake and chock the rear tires. This aint no Prius. These trucks are very heavy - especially in the front!
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDC Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
