Truck is a leanin' (Without the fat chicks) - Ford Powerstroke Diesel Forum
post #1 of 9 Old 03-19-2012, 07:06 PM Thread Starter
My 2003 leans a little on the drivers side, more towards the front. Well actually its more than a little, almost 2 inch difference. Checked all the springs, bushings, blocks, u bolts, shackles, ect. Everything appears to be ok. Nothing looks unusual from side to side.
Has anyone had just one spring pack get weak? I don't hot rod the thing and haven't hit anything.
And NOOOO, its not the driver either. I'm barely a buck fifty!
keckals is offline
post #2 of 9 Old 03-19-2012, 08:34 PM
"WTF" Stroker's Avatar
Thats funny. Without fat chick
05 F-350 CC SRW 4x4
4" MBRP
K&N Air Filter
Blus Spring
Banjo Bolts
Sinister Coolant filter
Edge Evolution
Updated STC
EGR Delete
Cat ELC
Atlas 40
SCT
176k
"WTF" Stroker is offline
post #3 of 9 Old 03-20-2012, 08:07 AM
I thought mine looked like that a bit. Then I checked...aaaaaaaand both rear leaf springs are broken. So I'm buying new rear leafs and throwing on some new Bilstein 5100's all around. I'm sure that'll help.
04 F350 SC LB: Warren Stock+ injectors, Sinister coolant filter, DC Power 185 amp alternator, EDGE Insight CTS w/ EGT, Diamond Eye 5" turbo back straight pipe, S&B intake, MTW Hybrid w billet wheel, Riff Raff boots, Studded, Strokers Unlimited fuel RR system
TruckNorris is offline
post #4 of 9 Old 03-26-2012, 07:21 PM Thread Starter
My first thought, but I looked at them and had a few others do the same, still nothing......
keckals is offline
post #5 of 9 Old 03-27-2012, 04:55 PM
jerg_064's Avatar
Got a leveling kit? Mine leans too on account of the previous owner putting on front add-a-leafs and not getting an adjustable track-bar. Can't remember which way it leans though so I may be off here.
And because of the extreme arch on the lower add-a-leafs they're digging into my bottom stock springs a good bit so now I'm having to replace those....argghhh, just gonna go with x-codes.
James
2003 F350 Ext.C LB, 6.0L, 4x4 6spd SRW
DIY egr delete, DIY 4" straight pipe, DIY coolant filter, DIY CCV mod, PHP FICM/ECM Rollback, SCT LW, SGII, Skyjacker Steering Stab, Rotella Ultra ELC, blue spring, etc....
jerg_064 is offline
post #6 of 9 Old 03-27-2012, 05:35 PM Thread Starter
I just installed a leveling kit. Still has 2 inches of "lean". I know it sounds funny but I think its getting more noticable. Im going to take the weight off of them and inspect them again.
What are they "x-codes" that you are talking about?
keckals is offline
post #7 of 9 Old 03-27-2012, 05:48 PM
jerg_064's Avatar
Think you misunderstood what I was saying.....By adding a leveling kit or changing the front geometry at all while still using the factory trac-bar, it'll pull down on the drivers side of the frame(or rather lift the pass side higher) and mess with your steering.
The x-code fronts are simply the heaviest duty factory front leafs, for snow plow packages & whatnot. It should put it a bit higher than stock, but not quite as high as the level kit. Which suites me, I'm a firm believer that rake is there for a reason.
James
jerg_064 is offline
post #8 of 9 Old 03-27-2012, 06:06 PM Thread Starter
Well maybe I do notice it more after the level kit because of the trac bar. Never crossed my mind!
You've just been stroked!
2003 6.0, TorqShift, EGR delete, Custom fuel spring upgrade, 3.5 downpipe 5 inch back, Glowshift gauges, All bulbs LEDs, 05' Headlights
keckals is offline
post #9 of 9 Old 03-29-2012, 05:18 PM Thread Starter
Unhooked my trac bar and drove it locally a little. Re-checked height, it helped about half a inch but it's still not right.....will have to look into springs I guess.
keckals is offline
