noise under hard accel - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-11-2012, 05:04 PM Thread Starter
tec548's Avatar
I have an 04' EX. Under hard excel above 50mph only there is a noise that comes from the rear end (almost a vibration but not quite). Normal driving there is nothing and below 50mph there is no noise either. I was thinking the diff... maybe, but it is only at higher speeds which I don't get. It's not related to engine rpm... just road speed. Any ideas?
Joel
04' EX 4x4 Limited, 6" ProComp suspension, Warn heavy duty front bumper with M15k, 84" Safari rack, MT 36/15.5/16 on MT 12/16's, 4" MBRP turbo back exhaust with 5" tip, Edge CTS Evolution monitor, STCx3 Extreme Street tuner, Blue fuel spring, ARP head studs, EGR delete, Coolant filter, 6.4 banjo bolts, Garrett PowerMax Turbo...
tec548 is offline
post #2 of 3 Old 03-20-2012, 04:36 PM
powersmoker1429's Avatar
Mine does the same. I hope someone can help lol
powersmoker1429 is offline
post #3 of 3 Old 04-03-2012, 11:29 AM
ryan.sampson's Avatar
did you check the ujoints?? and do the excursions have carrier bearings?
2002 F150 4.6L AUTO RCSB
SOLD:2004 F250 CCSB SRW 6.0 PSD AUTO
EGR Delete Kit / Livewire and EGT
Hercules FICM / ID Extreme / Vivian's Looney / Spartan Hybrid Race
A-Pillar 3 Gauge Pod w/ Fuel Pressure, Boost, Trans Temp
4" Turbo Back Straight Pipe / Blue Spring / 6.4 Banjos
7" Pro Comp Lift and Leveling / Zone Adj. Track Bar
36/15.50 Baja Claws on 20" Rockstars
13.882 @ 95.25 mph running 285 AT's
**Friends Don't Let Friends Drive Stock**
ryan.sampson is offline
