vibration at 65mph and oil on my diff?? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 02-15-2012, 04:44 PM Thread Starter
Iv noticed my truck has been getting a slipping and jolting feeling only at cruising highway speeds, i figured it might be my u joints so i crawled under to check for play only to find no play in the u joints however when i looks at the rear diff i noticed a black oily line (leak) that clearly came from the flang just behind the rear u joint at the diff. I am wondering if this vibration may be low diff fluid keeping in mind that the truck only acts up when i let it shift to overdrive at highway speeds any help would be great thanks guys
kal2005 is offline
post #2 of 11 Old 02-15-2012, 04:51 PM
superBADduty's Avatar
Quoted: 17 Post(s)
Garage
I know this isn't any help to you but I just started to notice a slight vibration starting at 70 mph and crawled under the truck and saw a line of oil on the diff as well. Funny thing is my driveshaft and oil seal were replaced not long ago. So not sure what's going on.
Sent from my Autoguide iPad app
2007 F250 KR CCSB 4x4 ARP's, PMM's EGR delete, PMM's coolant filter, SCT Sf3, GearHead's SRL & SRLXX, Rancho 7000's, IDP FICM tuning, blue spring, Wicked Wheel 2, No Limit Fab. CAI., 2008 rear differential cover.
2006 GMC Savanna 3500 6.6 LBZ Duramax work van
2008 F250 KR CCSB 4x4 quad buckets minimax "SOLD"
superBADduty is offline
post #3 of 11 Old 02-15-2012, 05:55 PM Thread Starter
iv done some searching around and got some other peoples input, iv been told that the leak is from the pinion seal a cheap $120 fix. However the vibrations at the 65mph over drive gear i cant really explain, my only hopes are that the diff didnt drain to the point where the damage is to far gone to the diff. With no play in the u joints im stumped??
kal2005 is offline
post #4 of 11 Old 02-16-2012, 04:34 AM
Quoted: 17 Post(s)
Garage
Yeah, I only feel it when it's in overdrive and 70+ mph, stumped as well.
post #5 of 11 Old 03-01-2012, 09:21 AM
Mine was the same way for the last few months and now my diff is really bad.On mine it's most noticeable when it shifts to overdrive but as it gets worse I'm feeling it all the time.Now it's at the point when it shifts to overdrive the truck bucks and bangs.I'm finding this to be a some what common problem with these trucks.Timken has a rebuild kit for about $300.
06 F350 6.0 auto 4x4 crew cab dually,stock for now.
PS/Fan is offline
post #6 of 11 Old 03-02-2012, 05:09 PM
Oil where the driveshaft and diff meet usually means bad pinion seal. Check oil in it and I would pop off the rear cover and inspect gears and everything.
05 F250 FX4 Supercab XLT LB 6.0 Torqshift ESOF, Boss V-Plow, Diamond plate running boards and toolbox, 105gal Diesel Tank 15GPM pump, 130+k Blue Spring Update, Sinister Coolant Filtration Scangauge 2
joe_r_dog is offline
post #7 of 11 Old 03-08-2012, 10:35 AM
While you're checking, take a look at your carrier bearing as well. Better yet, when you decide to replace the pinion seal, go ahead and replace the carrier bearing along with your U-Joints.
My carrier bearing went BOOM last month while pulling my 25' gooseneck (fully loaded). Luckily just the rubber bushing came apart so there was no real damage. I replaced the carrier and the u-joints with high end greasables.
Prior to the carrier going out, I began to notice a slight vibration that got worse when I lifted. The vibration came on about 60 miles prior to the failure. I wasn't in a situation where I could stop at the time.
Good luck to you.
Anoriginal is offline
post #8 of 11 Old 03-30-2012, 04:27 PM
I've only had my 06 250 for a little under a week now, not really to familiar with where everything is...so where is the pinion seal and carrier bearing ? When im on the highway about 60+ mph at crusing speed it vibrates as well, but when I open it up it clears up. I let one of friends who also has a 6.0 said he thinks it might be a steering issue (alignment ect..). Any chace it could be that, any adive would be appreciated.
wagner22 is offline
post #9 of 11 Old 03-30-2012, 05:12 PM
The carrier bearing is in between the 2 rear pieces of driveshafts.It's also called a hanger bearing because the driveshaft runs through it and hangs from it.The pinion seal is inside the front of the rear end where the yoke from your driveshaft goes in.Driveline vibrations you feel through your seat.Alignment issues come through the steering wheel.The way I check for driveline issues is to block the wheels,put the truck in neutral,crawl under the truck and start shacking and turning the driveshafts looking for play in the u-joints and yokes and listening for cluncks and hard metalic sounding clicks.Hope that helps.
PS/Fan is offline
post #10 of 11 Old 03-30-2012, 05:29 PM
it does, gives me somewhere to start at instead of just being in the dark, appreciate the info PS/Fan
wagner22 is offline
