Tie Rod Movement - Ford Powerstroke Diesel Forum
Old 02-08-2012, 12:29 PM
Tie Rod Movement
I had my front rotors turned today and after I put everything back together I lowered the jack and noticed my Tie rod will move, I can grab tie rod and twist it back and forth, no side to side just twisting up and down, should there be any movement ? I tried making a video to see if it helps explain my question
Old 02-09-2012, 08:01 AM
video link doesnt work. Seems it wants you to make an account..can you post to youtube
Old 02-10-2012, 05:17 PM
Not to be rude, but DUH! It's a ball joint! Yes that movement is normal. Side to side, no, twisty, yes.
Old 02-11-2012, 04:33 AM
DUH!! I know its a ball joint. It just seemed loose to me, I'm not left handed and it twist way too easy. Maybe I should just shoot a little grease behind the boots and call it good.
