Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum > 6.0 Drivetrain problems
Old 09-12-2007, 05:17 PM
orangesbc383 orangesbc383 is offline
Auto 4x4 2006 not working
Ive got a 2006 f-250 with auto hubs and the manual lever on the floor for the 4x4. Here's the problem when the hubs are in the auto position and i pull the lever into 4x4 it dose not engauge, I drove forward like 2000 feet and then backed up like 500 feet still nothing. I throught that when the hubs were in auto and i pulled the lever into 4x4 it would go into. I thought that the auto hubs worked off of vaccume? The 4x4 works great when the hubs are locked in. The truck only has 27,000 on the clock and i just bought it one month ago. Its going to the dealer saturday because of the brakes so, may have some more work for them to do. any info would be great
Old 09-12-2007, 05:27 PM
wetco416 wetco416 is offline
check the vacuum line on top of the hub on each side,mine were both cracked right there,just cut above the crack and reinstall.is your ac blowing only out your defrost?
Old 09-12-2007, 05:29 PM
nope my Ac works great ICE cold.... I will check that if i get a chance but like i said its only a month old so ill bring it to the stealership
Old 09-14-2007, 02:42 PM
bump bump...................
Old 09-14-2007, 02:44 PM
vitalidle vitalidle is offline
Desert Shield/Storm Vet
The vacuum seals could be bad.
Old 09-14-2007, 02:48 PM
najaf4life najaf4life is offline
Look Ma.. No Hands
one thing I really like about Ford is that you can still manually lock the hubs your self... cause the auto part of it isn't as good in my opion... and sometimes you have to roll a little bit for the 4wd to kick in... not if you just get out of the truck and lock it in your self... but hope you will be able to find out what the problem is and get it fixed....
Ryan
