- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
I have noticed in the last few weeks that periodically the wheel does not like to return and I have to jerk it to unlock it and if you are barely holding the wheel you can feel it quivering back and forth. I have check everything underneath and it is all tight and nothing is worn out. The only thing that I can think this possibly would be is the Steering box. Has anyone else had this problem? Do you know what is causing this and if so what?
| Sponsored Links |
+1 on checking the steering gear box... may have something wrong with the gears inside the box if its getting stuck.. as far as the wobbly wheel while driving, that is usually worn out ball joints, shocks, things like that... also reminds me of the way my NON power steering car acted b/c it would always want to follow the grooves/bumps/whatever of the road.. |
I was a tech along time ago, but, as a rule of thumb it was the p/s pump knows no direction. If it is failing you will have the same problems whether you turn right or left. If the problem is happening to one side, the spool valve inside the steering box becomes a suspect. Hope this can shed some light.
Hope all you had to do was add fluid.................
I sure hope that the only thing wrong was low fluid levels---Lord forbid you have to replace the power steering gearbox...............just got bitten by that bug myself to the tune of about $800.00 ![]() Regards, Jerry |
Ok so adding fluid did not seem to help the issue. I was going to order a power steering pump since I am fully convinced that is what the problem is. My question to everyone is; is it a pain in the butt to do? I was planning on doing this myself, but I have not worked on trucks much just my mustang. I hate to take things to the garage if I am perfectly capable of doing this myself. Please give me any info that may be of help before I decide to tear things apart myself. Thanks
It could be just a stiff u-joint on one side. I have the same problem now on my truck. Driving it with the front hubs locked stop the problem but I feel a vibration when I drive. I am going to check the u-joint this weekend
| Sponsored Links |
