noise when 4wd is engaged - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-12-2012, 06:33 AM Thread Starter
I have done some reading and searching on the forum and can't find a post with the same issue or symptoms so here goes:
I have a 2006 f350 4wd with the ESOF system.
When I put the truck in 4wd I hear a tin clanking noise from the passenger side front wheel area. I have noticed it before and the problem goes away when I take it out of 4wd and back up about 30 feet or so.
I have also noticed when I get out to move the lockers from auto to locked that the passenger side takes a lot more effort to turn then the drivers side.
Any help would be greatly appreciated
Thanks in advance
2006 F350 XLT
Crew Cab Long Bed 4wd
(Try to say that 5 times fast!!!)
2006stroker is offline
post #2 of 5 Old 01-15-2012, 01:40 PM Thread Starter
anyone even have a thought on what it could be?
2006 F350 XLT
post #3 of 5 Old 01-15-2012, 03:01 PM
Quoted: 58 Post(s)
Probably need to pull the hubs apart and inspect and service them. Might have a broken part on the noisy side, or the internals are just really dry.
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDCV Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Radius Arms
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #4 of 5 Old 01-15-2012, 03:18 PM
01strokin's Avatar
My 01 does the same thing, still haven't been able to track it down. Checked hubs, bearings and cv's. Only thing I'vefound is my inner hub seal and outer axle seal are way past needing replacement. I think it maybe causing to much pressureon the outer "none serviceable" bearing, only thing i haven't had time to check.
01 f250,kumho kl71s,TYMAR intake , 4inch mbrp
01strokin is offline
post #5 of 5 Old 01-15-2012, 05:04 PM Thread Starter
Thanks. I will check the hubs first.
Truck has a little over 82,000 miles on it and is all stock.
How long do the hubs usually last?
2006 F350 XLT
