Camber sleeve, how to remove and install - Ford Powerstroke Diesel Forum
Old 12-18-2011, 09:35 AM
OK, I have gotten my front end apart to replace the upper and lower ball joints. I was told about a year ago when I went to get my 2004 F250 inspected that I needed upper and lower all joints and camber sleeve bushings. How do you remove the camber sleeves?
Thanks, Kelly
Old 12-26-2011, 06:23 PM
When you remove the upper ball joints, they are the sleeves that take up the space between the knuckle, and the ball joint studs.
