Dually E-Brake problem - Ford Powerstroke Diesel Forum
Old 11-30-2011, 10:19 AM
Send a message via AIM to BennyLumpkin
So my 06 Dually e brake doesn't work....doesn't even try....what gives?
Old 01-04-2012, 06:15 AM
Check your brake backing plates, they rust around the 2 pins that hold the drum pads in place. So A cheap fix is stainless washers with longer pins. I went to napa with the old pins and they matched up the same but longer. It has been 3 years now and I use the e brake whenever it is parked. New from ford backing plates around $150 EACH. Hope this helps.
