noise when turning left... - Ford Powerstroke Diesel Forum
Old 11-06-2011, 08:39 PM
I am getting a moaning noise from the right front when im turning left. I suspected a bad wheel bearing. I replaced upper and lower ball joints on both sides and replaced both front hub assemblys. Noise is still there....dont really know where to go from here. suggestions??
Old 11-06-2011, 10:39 PM
I had a similar noise. Replaced the ball joints that had rusted solid, pulled the hubs and found one leaking grease and the other with a bad spot. Went for a test drive thinking I had solved it and it turned out to be a bushing on one of the front shocks.
Old 11-06-2011, 10:44 PM
spool up that turbo!!
Jack the truck up undo the snap rig on the locking hub pull the hub out (just the locking portion) and spin the wheel see if its the hub because my 01 does the same thing the internals of my locking hub are shot hope it helps
Old 11-07-2011, 08:10 AM
yep, replaced those too.... no luck.
Old 11-07-2011, 08:13 AM
Im not sure that would work, it only makes the noise when it has a side load on it. if Im making a slow left turn in a driveway or something its fine. I has to be a sweeping turn with a pretty decent side load if you know what I mean.
Old 11-07-2011, 11:46 AM
[quote=yfzjim;2745198]Im not sure that would work, it only makes the noise when it has a side load on it. if Im making a slow left turn in a driveway or something its fine. I has to be a sweeping turn with a pretty decent side load if you know what I mean.[/quote
Mines the same way
Old 11-07-2011, 11:48 AM
But you could rattle the hub around
Old 11-07-2011, 03:11 PM
I will try it then...
Old 12-13-2011, 03:58 PM
Did you ever solve this problem? Mine just started doing this and before I go ripping everything apart i'd like to know how you solved this.
Old 12-14-2011, 03:10 PM
Mine just started making a grinding noise when I'm turning left also, but I have to be accelerating into the turn for it to make that noise. I imagine this type of issue would be hard to diagnose.
