More of a question than a problem
I just purchased an 05 F350 4x4 longbed crew cab with the 6.0. My question is in regards to the rear differential. My F250 had posi-track (or what ever ford calls it) but I'm not sure this one does. The other day I was turning and when my right front tire went up on a small bump, the right rear tire spun. Does anyone know if this truck is equipped with the clutches in the rear diff?
I read the owners manual and it's no help. Figured I take it to the experts here before I allow the dealer to lie to me.... |
There should be a tag (or two) on the rear diff cover. Write down the codes and post them
I believe the driver's side door sticker will also have an "L" in the axle code if your truck came with it.
I couldn't find an axle code on the door sticker but I did get the info from the tags.
First tag: V 445 B L 73 10 2 4L22 Second tag: 5W140 SYNTH OIL ONLY What's the call? |
Limited slip, 3.73 gears
Thanks.
#@$%&$#@! That means I may have clutches out. Maybe I'm not testing it right. Any ideas on a good test? Don't they normally pop and jerk when they are going out? Tomorrow, I'll jack up one side and try to spin it. Thanks again. |
Or, is the limited slip the one without the clutches?
Limited slip has a clutch pack. Just because you had a wheel off the ground and it spun, and the other side didn't, doesn't mean there is anything wrong. Limited slip differentials just plain suck in that situations. It is NOT a locker, so it will not lock like you think a limited slip would.
Okay. That's what I was thinking. My 250 had the Traction Lok diff. I'll look into converting this one to what I had before. I spend a lot of time in sand washes and absolutely hate shoveling.
Thanks again for your help. |
