Driveline vibration after lubing slip joint - Ford Powerstroke Diesel Forum
Old 11-02-2011, 08:13 PM
I dropped the rear drive shaft on Monday to lube the slip joint. No problems there. Re-installed the u-joint in the same location on the yoke and now I have a vibration around 65 mph and up. Nothing below 65. Is there some alignment on these joints? When I put it back together it didn't seem like there was any side to side movement.
Old 04-09-2012, 02:40 PM
side question... how'd you lube the slip joint?
Old 04-10-2012, 08:10 AM
I had to remove the drive shaft by unbolting the u joints on each end. Then removed the steel band on the rubber boot allowing the shaft to slide apartment packed the splines with grease and reassembled. I used a large wire tie to replace the steel band.
Sent from my Autoguide iPad app
