Stuck in 4wd please help
Ok i engaged my 4wd yesterday and went to take it out and it is stuck in 4 low!!! I changed the selector motor on the transfer case in good hopes that it would fix it and that did not fix it!!! It is electronic 4x4 and it seems as if i am not getting power to the selector motor i checked the fuse and it was fine!!!! I am lost
Not sure if this will help or not, but it might be a vacuum leak. Do you notice your A/C switich from the vents to the defrost whenever you try switching the 2WD-4WD switch on the dash? If so, it very well could be a vacuum leak. Other than that, not really sure... here's a bump for you though. Let us know what it was if you already figured it out.
04 transfer case issues
goto permalink #5 NYC F-350 has very good info Need to repair my auto 4X4.... Last edited by 05harley; 10-21-2011 at 05:10 PM. |
Are you in neutral or park? I have to be in neutral for my to come out of low. just a thought.
