stuck caliper - Ford Powerstroke Diesel Forum
post #1 of 3 Old 09-12-2011, 03:50 PM Thread Starter
06SuperDutyF250's Avatar
stuck caliper
so i was driving home today from the dealer in Long island bc i took my aunt out there to lease a 11 ford explorer, so on the way back about 20mi or so from the dealer the truck starts pulling to the left, i can smell burning brakes, as i got too about 5 miles from my house at a red light the driver side front caliper was stickin it started to smoke. so i stop let it cool then get home. The wheel is real hot and can smell burnt brakes. so i call my dealer up he says if its bad caliper its under my warranty and theyll fix it. im like great, so now about 2hrs letting the truck sit i go to my job where i have all my tools which is about 4-5miles away. I take the wheel off and remove the caliper and all. So i go to compress the cylinders and to my suprise they both went in. I took a look at the pins and they were kinda dry. i regreased them with caliper grease and put it all back toghter and did the passenger side for the hell of it. Do you think the slide pins would be enough to cause this? or is the Caliper on its way out? i had one caliper on another car sieze and you couldnt even compress it. but thats not the case here. when it was sticking i would hit the brakes and it would pull hard to the right to counteract the stuck caliper. but now after i regreased it, it hasnt done it anymore and both wheels feel the same temp and it doesnt pull anymore stays striaght. it just did this out of the blue. any thoughts? thanks
06SuperDutyF250 is offline
post #2 of 3 Old 09-12-2011, 04:54 PM
silversuper's Avatar
anythings possible when it comes to cars and trucks man. How long until your warranty runs out? I say run it til it brakes more
Rich
2003 f250 4wd 6.0 diesel crew cab long bed Lariat.
119k on the clock, stock
has: tires, edge insight monitor, new ICP sensor and connector, new front pads and rotors, PMM EGR delete kit, new oil cooler, BOSS 9' plow
needs: tuner, coolant filter kit, blank check
silversuper is offline
post #3 of 3 Old 09-12-2011, 05:32 PM Thread Starter
i have my warranty for another 34K, right now its acting perfect and actually feels like i have a bit better brakng, maybe the pins were dry and caused it to hang up the rubber around the pistons looks pretty worn, probably gunna bring it in next momday if it stays the same...
