Loose leaf springs? - Ford Powerstroke Diesel Forum
Old 07-31-2011, 11:42 AM
Loose leaf springs?
When I hit a bump in my 04 f350 I hear a clunking noise in the front left side and can feel it a little bit on my feet. Could this be my front left leaf spring?
Old 07-31-2011, 11:56 AM
Send a message via AIM to PowerstrokeTech82787
Check to see if the leafs are cracked if not its either ball joints or sway bar bushings. they make one hell of racket when they get bagged out.
Old 07-31-2011, 12:03 PM
Old 07-31-2011, 12:05 PM
I'm gonna go grab a picture of the sway bar real quick
Old 07-31-2011, 01:01 PM
what for? take and pry up and down on it if its moving with little resistance there ya go sway bar bushings...
Old 07-31-2011, 02:44 PM
Alright I'll try that. Thanks
Old 07-31-2011, 03:13 PM
Feedback Score: 7 reviews
More than likely it's the sway bar end links-they cause a hollow knocking sound when bad-just go underneath and try to pry the swaybar up and down. Any play and you need new ones.
Old 07-31-2011, 03:32 PM
will these fit a f350?
Energy Suspension 4.5186 Complete Front Sway Bar and End Link Bushings Set - 32mm - 1.5 Inch Endlink Eyes
Old 07-31-2011, 03:33 PM
The bushings for the swaybar should if the diameter is the same, however the endlinks are non rebuildable, and only cost around 40 bucks for both sides new.
Old 07-31-2011, 03:38 PM
alrighty ill order them
