Wheel bearings in a 04 6.0 - Ford Powerstroke Diesel Forum
Old 07-20-2011, 10:26 PM
I had my new tires put on today and they said i will need my wheel bearings replaced soon. anyone done these and how hard are they. i dont want to pay someone to do it if i can figure it out.
Old 07-23-2011, 11:41 AM
SIMPLE! Did them once to replace them and another time I had to take them off to pull the axle shaft out to replace the inner axle shaft seal. The hardest part is getting them off. They are held on by 4 studs (sometimes the nut will be seized on and the stud comes out no biggy) Just takes a little time hitting a little at a time in a circular pattern around the hub. You can use a puller also but I never did. When you do the bearings it comes as a whole hub assembly wheel studs and all. Around $400 a side. So if you can do it yourself it is worth it. Tires off, calipers, rotors, 4 wheel drive hubs off behind the locking hub will be a split ring on the inner axle shaft take those off along with washers. Then you are ready to attack the bearing hub nuts. Look on the back easy to spot there is 4. Then some muscle and off the hubs come and reinstall! Once you get into it you be glad you didn't pay some one to do it. Sometimes they come of easy some times they are a REAL pain just be patient and keep with it an you'll get her done! Goodluck!
Old 09-01-2011, 05:21 AM
I was having a grinding noise come from the front when i turn to the left.Ended up pulling wheel hub out and bearing was bad.The front hubs are around 400.00 but if u look close there are two bearings or what i was told.My problem was the small bearing the shaft rides in.You can replace it by itself and cost me 25.00.I took the number off the bearing and went to my local bearing shop and got it there.It wasnt all that bad to do but took sometime to get the retaining clip off axel to get hub off.
