U-Joint Replacement gone wrong; Need HELP QUICK!! - Ford Powerstroke Diesel Forum
Old 06-25-2011, 04:51 PM
Feedback Score: 8 reviews
I've had a vibration in my drive line/axles for a bit now - It seems present at around 65-80mph. It definitely feels like it's in the rear drive line somewhere.
I decided to go ahead and replace the u-joints and carrier to see if they were the culprits...
Long story short - I wound up having to buy a press to get the u-joints out - THEY WERE S T U C K!!!! Trying to get the front most u-joint out (the one closest to the transfer case, I wound up cracking the Spicer piece that bolts to the transfer case.
(a) What is that piece called? It has Spicer # C3-2-811 stamped in the casting. Is it a "flange yoke"?
(b) Where can I get a replacement? Ford? Straight from Spicer? I need the thing ASAP!!!
Any help would be great.
Old 06-25-2011, 05:09 PM
information regurgitator
Fairly certain you can get that yoke through NAPA, but you will likely have to order it.
Old 06-25-2011, 06:16 PM
Here's the damage....What should I be asking NAPA for?
Old 06-25-2011, 06:21 PM
shaking things up
Napa or any good parts store could get it
Old 06-26-2011, 06:27 AM
No luck at NAPA or any of the other local places for me........... I want to scream this has pissed me off REALLY BAD!
Old 06-26-2011, 06:32 AM
Nobody will have that part on hand. It will have to be ordered. NAPA wouldn't order it for you?
Old 06-26-2011, 06:34 AM
Didn't even sound like they could get it. They didn't show a listing.
Old 06-26-2011, 06:38 AM
Rob Rob is offline
Go to ford or any local driveline specialty shop. Like mentioned before, it will most likely have to be ordered.
Old 06-26-2011, 06:39 AM
Then whomever you talked to at NAPA was the wrong person. It is a SPICER piece with the number right on it.
Either that or you will have to go to the FORD dealer and order it.
Old 06-26-2011, 09:45 AM
I'll try NAPA one more time with the P/N - I did find the part on fordparts.com using my VIN, but I can't even order it 'til tomorrow.
[edit] Just tried NAPA again; no dice. What is wierd is that I've tried to search for this casting number via Google and haven't found ANYTHING even close; I've found tons of Spicer flange yokes, but not this one....
