Bolts for Sway bar - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-31-2011, 12:48 PM Thread Starter
Bolts for Sway bar
Hi guys;
Just a quick question, I just put on the Energy suspension sway bar bushing kit and I noticed the bolts I took off had a shoulder on the end of the bolt. Now when installing the new bushings it doesn't look like the bushings on the drop links are tight enough. The sleeve insert is hitting the shoulder and not collapsing the bushing.
Is this the way it should be??
Thanks..
Gibby206 is offline
post #2 of 3 Old 05-31-2011, 03:14 PM Thread Starter
A few pictures to clarify the problem...
ID:	25968   Click image for larger version
Gibby206 is offline
post #3 of 3 Old 05-31-2011, 03:24 PM
99PSD-White's Avatar
more washers on the bolt head end.
2013 F250 Lariat 4x4 Loaded. H&S mini maxx, 5" exhaust, S&B intake, and EGR delete, AMP steps, tonneau cover
2011 F150 Ecoboost FX4 Screw. All stock except for a livernois Tuner. SOLD!
Early 99 CCLB Pro comp 6.5" lift w 18" hulk wheels wrapped in 37" KM2s, Amp steps, Straight pipe, AIS intake, Dp Tuner, isspro gauges (boost,trans,pyro), 05 front clip, traction bars, 6.0L trans cooler, built trans.SOLD!!
99PSD-White is offline
