Driveline / Carrier Bearing / Lift Kit Help
Ever since I swapped out my 4" rear blocks for 5.5" ones, I've been getting a noticeable vibration under moderate acceleration from 8-12mph. I currently have two 1/4" shims on the carrier.
The Ford dealership told me they think my pinion angle is off, and I have the wrong lift blocks. I got the angled ones (installed facing correctly). Got home and put a magnetic protractor to each piece of the two piece driveline and saw they were approx 2* apart. So I put another 1/4" shim in, which brought em within .5* apart. Took it for a drive, and I'm still having a vibration around 10mph. Not as bad as before, but still there. Any advice? |
how much play do u have in ur carrier bearing? i have a good amount and i have the same issue. i know that thats the issue just havent got around to switching it out. also do u have a carrier bearing drop kit?
It's a brand new carrier bearing, and it's shimmed/dropped about 7/8" now.
hmm maybe a bad universal joint. idk u got me...
