Reinstalling rear hubs..need help
Long story short my rear brakejob has opened up a can of worms when I found some other things needed replaced. $800 later and I have the hubs off but having trouble reinstalling them. I think the rear hub seal is stuck on the spindle..anyone have experience with this? I'm in Pittsburgh if someone is generous to lend a hand.
I guess I am confused, you have the rear hubs off?? So I am guessing you unbolted the axle shafts when you say this. What are you attempting to do as far as rear brakes goes? pads and rotors or is the emergency brake bad too?
Ha..um was just planning on doin rear brakes plus rotors..however wheni pulled off rotor the ebrake assembly was laying in there because the dust shield that holds ebrake together is totally shot. And on driver side I've needed to replace the hub becasue the axle bolts broke off inside..so I have both hubs off.
