Rear brake backing plate - Ford Powerstroke Diesel Forum
post #1 of 12 Old 04-07-2011, 04:48 AM Thread Starter
nylyon's Avatar
I recently discovered an issue with the parking brake on the right rear of my truck. When I removed the rotor / parking drum assembly I found the parking brake hardware in numerous ground up pieces. I've removed all the loose parts and put everything back together to make the truck drivable. When everything was apart, I noticed that the backing plate is rusted through. Does anyone know the part number for this plate?
I also found what I think is an aftermarket plate as well. It's DORMAN Part # 924-212. Has anyone purchased this plate and did it fit properly?
- Karl
2003 F-250 Crew Cab Short Bed Lariat PSD 6.0 Automatic FX4 Edge Insight with EGT Probe. Coolant Filter. All 6.0's need gauges
nylyon is offline
post #2 of 12 Old 04-07-2011, 05:18 AM
information regurgitator
NYC F-350's Avatar
Quoted: 51 Post(s)
Looks right to me. I have used plenty of Dorman parts in the past. Fit and finish have always been acceptable.
Please
You could save the life of a sick child
NYC F-350 is offline
post #3 of 12 Old 04-07-2011, 05:23 AM Thread Starter
nylyon's Avatar
I think that I'll order it up. It will be nice to work on another part of the truck than the engine!
- Karl
nylyon is offline
post #4 of 12 Old 04-10-2011, 04:02 AM
blue06crew's Avatar
Haha I am having the same problem. $185 for that backing plate per side!..both of mine are junk, driver side hub needs replaced as well as brakes and rotors..all on my 2006. IRS tore apart waiting on parts..not happy that I have $800 in it so far when I just planned on a brake job
2006 Ford F-250 4x4 Crew Cab
SCT- DJ's Looney
AIRDOG 2
6" Rough Country 4 Link Suspension
2" billet spacer/f350 rear block
AFE air intake
5" MBRP turbo back exhaust with 6" tip
Autometer Sport Comp Guages
38.5x14.5x17 Pro Comp Xtreme ALL Terrains
17x10 Diamo Black 17 Karat Wheels
RCD EGR delete
Custom Traction Bars
Recon Smoked Mirror Lights/Cab Lights
03 Turbo
to be installed:
Whatever i buy next...
blue06crew is offline
post #5 of 12 Old 08-08-2011, 04:12 PM
Please tell me that there is a cheaper place to buy this little piece of tin!? Is the dust shield a seperate piece... or is it all one piece? mine is so rusted I can't tell.
06' F-350, 6 Speed, Day Cab, Long Box, Single Rear, Leveled, 4" Turbo Back, EGR Delete, Coolant Flush, Coolant Filter, Livewire, Erics Tunes,
FordFarmer10 is offline
post #6 of 12 Old 08-08-2011, 04:17 PM
NYC F-350's Avatar
Quoted: 51 Post(s)
http://www.amazon.com/Dorman-924-212-Brake-Backing-Plate/dp/B002799EEA
Please
post #7 of 12 Old 08-08-2011, 04:34 PM
That just looks like the dust shield. Is that what i need? Is that the same as the backing plate?
post #8 of 12 Old 08-08-2011, 04:37 PM
Also is there any place to get the little arm that spreads the e-brake pads? The arm that attaches to the cable. Mine is rusted solid and doesn't spread apart anymore.
post #9 of 12 Old 08-08-2011, 04:39 PM
NYC F-350's Avatar
Quoted: 51 Post(s)
That is the piece that bolts to the axle tube.
Please
post #10 of 12 Old 08-08-2011, 04:39 PM
Also that part number was for up to 04's. I need 06.
