transfer case mounting gasket - Ford Powerstroke Diesel Forum
Old 04-06-2011, 01:32 PM
Is there a gasket between the 6 speed manual trans and the manual shift transfer case? The haynes manual says there IS one but I have the transfer case and tranny out right now and there was NOT one when I took it apart. The trans and t-case both have their own seals and don't share oil...should there be a gasket there for some reason...?
Old 04-06-2011, 01:39 PM
yes, transmission fluid will leak out. Transfer case is a sealed unit.
Mines an 01 (99 same way). Theres a gasket on the back of the trans(mating to thre adapter housing) then one from the adapter housing to the transfercase. If you do not seal it it will leak. Mine if I just use sealant it will leak. The way the transfer cases are they are not totally solid. I am not describing that right, but its not like a 1" inch flat area meeting another. Theres slots cut into the transfer cases. The thick ford gasket is better. If you need, I have the part number for my 01. It may not be the same but it can show them at the dealer what you are referring too.
Old 04-07-2011, 04:09 AM
Ok, thanks. Guess I'll have to stop at the dealer to get it, as much as I hate buying anything from them...
