Front axle seals? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 04-02-2011, 09:31 PM Thread Starter
dz4swamper's Avatar
Front axle seals?
So I took my front wheels off to inspect my brakes today, and noticed what looks like a part of my front axle seals just spinning on there. it could be the dust boot for them since there's no fluid leaking.
Anyone have an idea what's involved in changing these and what the parts would be?
Thanks,
Sean
2004 CC/LB F-350XLT 6.0L
Banks techni cooler
Banks High Ram intake and boost tubes
4" Exhuast
Banks IQ
SCT
Tuned by Vivian (Street, Looney, Looney Wild, Tow and Tow Aggresive)
ARP studs
Black Onyx HG
Cat ELC
CCV mod
No Kitty
Diesel Site Coolant Filter
dz4swamper is offline
post #2 of 9 Old 04-03-2011, 05:26 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
If you are talking about the ones that are by the axle tube opening, they are just dust seals. To replace them, the hub assembly will have to be removed and the axle pryed out. You will then have to replace the vacuum seals that get damaged when you remove the axle. IMO, leave it alone until you need ball joints.
dhanna6powerstroke is offline
post #3 of 9 Old 04-03-2011, 05:30 AM
usnavyad's Avatar
Feedback Score: 3 reviews
If its anything like a 7.3l set up that is Ur dust cover and very easy to swap out the iner axel seal u may need to take to Ford and have them press it on with a tool
usnavyad is offline
post #4 of 9 Old 04-03-2011, 05:38 AM
Mod Newbie
Quoted: 20 Post(s)
They are the same setup but that's a lot of work to just replace seals. If you're gonna go that far, you would be better off to replace the ball joints at the same time.
post #5 of 9 Old 04-03-2011, 05:42 AM
usnavyad's Avatar
Agreed thats when I did mine when I did the ball joints check your hub bearing also and replace Ur yellow seal
usnavyad is offline
post #6 of 9 Old 04-03-2011, 05:49 AM
Mod Newbie
Quoted: 20 Post(s)
Here is a great write-up. Will show you everything. Just ignore the ball joint section if you don't want to replace them but I would do it all while you're in there.
Ford Super Duty Ball Joint Replacement Procedure | Superdutypsd.com
post #7 of 9 Old 04-03-2011, 06:46 AM Thread Starter
dz4swamper's Avatar
Roger that. Thanks guys yeah, it's just the dust seal and I'll just leave it alone until I have to dig in there. Ford replaced the ball joints under warranty for the previous owner according to the oasis report.
Thanks for that website link!
Banks techni cooler
4" Exhuast
Banks IQ
SCT
ARP studs
Black Onyx HG
Cat ELC
CCV mod
No Kitty
post #8 of 9 Old 04-03-2011, 06:49 AM
usnavyad's Avatar
No prob petty officer this is ad3 BTW lol check out my post on pre and how did u get Ur crow on here
usnavyad is offline
post #9 of 9 Old 04-04-2011, 05:09 AM Thread Starter
dz4swamper's Avatar
If you go to the website on the banner, it should walk you through how to make your own on the website, then just paste the code into your sig and youll be good to go PO3
Banks techni cooler
4" Exhuast
Banks IQ
SCT
ARP studs
Black Onyx HG
Cat ELC
CCV mod
No Kitty
