06 F250 vibration at speed - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-02-2011, 10:36 PM Thread Starter
Hey folks, new to the forum, and new to diesel ownership. I just purchased a new-to-me 2006 F250 FX4. I has 164K on it. It's in great shape, looks like the previous owner took good care of it.
I am experiencing a vibration/low freq hum somewhere in the driveline. It has done this from day one, but has seemed to gotten worse recently after I have done some work. It looks like the previous owner had hit something pretty hard on the left rear tire, as the rim had a chunk taken out of it. I replaced my wheels all the way around with some aftermarket rims, and kept the same tires, as they are almost new (stock 17's). While I was doing all of this, I noticed the U bolts holding the axle to the spring, as well as the alignment bolt that goes through the leaf springs, were bent pretty good. I replaced all of these, and it straightnened up the rear end. I then took it and had it aligned, since previously, after they smaked it around, they just realigned it. So now my truck tracks straight, and all looks good. Also, the tires were balanced and inspected by the ford shop, and i was told they were good, not out of round. The only issue is that it seems to have made the vibration worse. I can reproduce it one of 2 ways:
1. Get on the gas hard from a stop, and it will do it until I let off the gas, be it 20 or 70 MPH. As soon as I let completely off the gas, it subsides somewhat, to where it is pretty much gone.
2. Hit the gas pretty good anywhere over 40mph or so, and once again, it seems to go away almost completely after I let off.
I am going to replace all the U joints and carrier bearing Friday.
I also dropped the rear end pan and inspected, it looks good, and refilled with royal purple synthetic gear lube.
I checked the level in the transfer case, and it looks good. I did not change the fluid though.
After the ujoints/carrier bearing, I'm out of ideas. Any help would be appreciated.
Thanks!
txtraveller2002 is offline
post #2 of 6 Old 03-10-2011, 01:03 PM Thread Starter
Update- It was the rear U joint. It had grenaded. I replaced all ujoints and the carrier bearing, and it's all smooth as silk now.
post #3 of 6 Old 03-11-2011, 10:25 AM
Do you have the part numbers for the universals and the carrier bearing? Did you do it yourself? Any pics or tips for the DIY?
Shane "Syko" Jago
2006 Ford F-250 Crew Cab(purchased 09 Mar 06)
Wedgewood Blue Lariat
BFGoodrich Radial All Terrain K/O 285 70 R17 on Ford XLT Alcoas
Lot's of doo dads. but bone stock in the power department
SykoStroker06 is offline
post #4 of 6 Old 03-12-2011, 12:16 PM
Bump to anyone who has done this. I am looking to do it, but have never done it on a Ford F-250. I just don't want to open up a can of worms. I plan on replacing the carrier bearing and all (3) universals.
Shane "Syko" Jago
post #5 of 6 Old 03-14-2011, 01:16 PM Thread Starter
I don't have the part numbers, sorry. They were precision brand u joints. The carrier bearing was made by Moog. I have an O'rielly's warehouse in my town, and they had all of it in stock, I just bought the good stuff, they will be able to look it up. It wasn't that bad of a job, it took my borther and I about 3 hours total (including running back to the parts store to exchange the carrier bearing). And i also sanded and repainted the drive shaft. Probably the hardest part was getting the bolt off the end of the slip joint to free up the carrier bearing. I don't know who put that thing on there, but it took about 8 feet of cheater bar to get it broken loose. Other than that, as long as you've got a good vise to put the u joints back in, it's pretty straightforward.
post #6 of 6 Old 03-15-2011, 11:56 AM
Thanks. Now I just have to order the parts and get to it.
Shane "Syko" Jago
