transmission slip??? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 02-14-2011, 07:08 PM Thread Starter
asian195's Avatar
Quoted: 2 Post(s)
My tranny is starting to slip. just at cruising speed it will act like its going into neutral for a second or two. it also has a big delay when shifting from reverse to drive. it doesnt do it all the time. ive read something about solenoids going out. how do you know if its the sensors? how many are there? whats your opinions on this? does it sound like a rebuild or solenoids? thanks guys.... oh yeah, ive got 67K miles on it...
2003 F-350 6.0L.
Leveling kit
35/12.50-20 Federal Couragia M/T
20x10 black Fuel Hostage wheels
4"-5" exhaust no cat
Airaid intake
SCT tuner-awaiting custom tune
Edge Insight CTS
Blue spring
6.4 Banjo bolts
Zoodad mod
EGR Delete
ARP Head Studs
To Do/Wish list:
FICM tune
BPD Oil Cooler/Filter
Fog light mod
Harpoon mod
Injectors 155cc
asian195 is offline
post #2 of 5 Old 02-16-2011, 08:11 PM Thread Starter
asian195's Avatar
Quoted: 2 Post(s)
bump.........
2003 F-350 6.0L.
Leveling kit
Airaid intake
Edge Insight CTS
Blue spring
6.4 Banjo bolts
Zoodad mod
EGR Delete
ARP Head Studs
To Do/Wish list:
FICM tune
Fog light mod
Harpoon mod
Injectors 155cc
asian195 is offline
post #3 of 5 Old 02-21-2011, 09:56 AM
Send a message via Yahoo to chuckles
Yeah, mine has begun with similar symtoms. about a 2 to 3 second delay going into reverse and the 3/4 shift has that "neutral" slip between the gears. I've had this before, and usually a return to stock programming and drive for a bit, then reflash my pcm with my IDP tune and all is good. But lately this seems to not help any.
Chuckles
07 F350 King Ranch. SCT by Innovative!!
4" Magnaflow Turboback, Coolant Fiter System, ARP Studs, Sneaky Pipe by Elite Diesel.
chuckles is offline
post #4 of 5 Old 02-28-2011, 05:42 PM
Update:
Replaced the direct drive and EPC solenoids, cleaning the solenoid body, and pan, then replacing screen and bypass element, appears to have fixed my issue. 10 new qts of fluid also.
Chuckles
chuckles is offline
post #5 of 5 Old 03-27-2011, 07:39 AM
update. issue came back. Reflushed everything and replaced torque converter. Issue gone now for over 500 miles.
Chuckles
chuckles is offline
